Hi All
I've got Community Fibre doing an FTTP (Fibre drop from telegraph pole) install soon and I'm trying to prepare for it. I hoped to be able to utilise the existing overhead cable bracket mounted on the facia board on the corner of the roof (currently in use for BT drop).
I'm planning on running the drop cable up into the UPVC soffit, then into the loft where it would only be a metre before it would then go down into the ceiling of the nearest room's corner. The ONT (fibre box) would then be mounted on the room's internal wall. The cable run from the ceiling to the ONT would be about 6 metres.
Just wondering if you knew the following:
1) I understand that the drop wire (cable) is only 2.5mm dia but I'm presuming it's pretty robust. I was thinking of running it through some 16mm mini trunking but it will will have some 90 degree turns en route, so...
Does anyone know what the min bend radius of this stuff is?
2) After the installers have anchored it on the bracket, I envisage myself poking the cable into the soffit then getting in the loft pulling it across to where it will go through the ceiling (5 min job - good access). Then, giving it back to them to finish up. Hoping they'll be OK with that as I know lofts can be out of bounds for them?
3) Wondering if the 6M run internally is not too long for them to approve or reasonable?
Many thanks
Many thanks
