- Joined
- 23 Jul 2023
- Messages
- 5
- Reaction score
- 0
- Country
I want to know your thoughts on this please. We spoke to our joiner a friend of ours) before this work and were reassured it is perfectly fine.
We're in the UK. We're doing our loft with the help of a joiner, roofer and electrician.
Our house is 130 years old and our roof is supported by 4 12x6 purlin beams. We have a load bearing wall that goes right down the centre of the loft, parallel with the purlin beams. Loft floor is 16ft x 16ft.
The joiner couldn't reach the exterior front and back walls due to the lack of space and inability to reach without coming through the ceiling (the old ceiling joists were bowed and weak and have since been screwed to the new floor frame for stability). He fitted vertical 6 x 2 batons onto the purlin beams (8 of these on each side of the loft) and hung the floor frame off those. All of this held together with nails, I have since reinforced the vertical batons with M10 coach screws with washers into the purlin beam and also the beam the floor joists are hung from.
All thoughts welcome on whether this will be sufficient for the load of a spare bedroom or if there's anything else we need to consider.
