3600 watt oven & 1250 watt microwave - which cabling?
Nope that wouldn't bother me. It's the oven over 3kw on a plug top that I wouldnt do.
If it's just the plug/socket that concerns you, then I can understand that view.
What would you say if it were fed from a 13A FCU (or a circuit protected by a hypothetical 13A MCB) with (now permitted!) 1mm² cable?
Thats never really been the case, 13 amp plug tops are no good for 13 amps for long periods.
Well, experiences seem to vary. I've seen 3kW immersions (probably the 'worst possible' type of load) fed via plugs/sockets for years without any problems.
However, as you say, it seems that such is far from always the case - and, at least in my opinion, that is just plain wrong!
Just the same in my opinion, I've come across so many burnt out spurs from 3kw immersions, never an oven though to be honest, I just wouldnt take the risk, not worth it for me.
I presume you mean 'burnt out' FCUs, not the spur (cable), presumably due to the fuse/holder (or maybe a 'loose connection')?
So, attempting to 'drill down' to what it actually is that concerns you, it sounds as if it's probably the 13A fuse (and holder), whether in a plug or an FCU is it? If so, I can understand your concern, given the number of people who seem to have that problem - albeit it's usually the high loading of a double socket (e.g. with WM + dryer) that gets blamed.
Yes FCU sorry
