And remove all electrical safety devices as a good sharp shock is better
I don't think that's a fair analogy. Don't you agree that it is better if the thing that first brings a blockage (of drain/sewer) to one's attention is smelly gas bursting/bubbling out of loos/basins/sinks/whatever than for the first 'sign' to be when sewage starts backing up into those loos/basins/sinks/whatever?
As for your attempt at an analogy, we
do always have to remember that, in a wide range of fields, introduction of protective measures can result in complacency, thereby undermining some of the potential protection afforded by the measures. ... i.e. I'm sure there will be at least some people who (even if 'subconsciously) be less careful when playing with electrical things than they would were it not for RCD protection, and at least some people who drive 'less carefully' than they would if their cars didn't have seat belts, airbags, crumple zones, ABS etc. etc.
I can't explain that but to use an electrical analogy, again, 230v is always potentially dangerous. Where do you draw the line?
As you know, that is often debated, and has to be a matter of personal judgement but, again, it's not really pertinent to what we're talking about here
I don't profess to have all the answers but reasonableness must come into it. After all,
It should, but unfortunately, that's not always the case with laws.
However, I've looked more closely and have found what may be the cause of the confusion (even though it doesn't really 'clarify' anything).
I had forgotten that, whilst the Building Regs require all 'building works' (other than most electrical work) to be notified unless they are explicitly exempted in Schedule 4, it's definition of 'building works' is pretty limited (as well as very unclear!!). The nearest to anything relevant in the Intr0duction is the statement that anything counts as 'building works' if it is a 'cotrolled service' which, in turn, it defines as something for which requirements are imposed by any of a number of 'Parts' in Schedule 1, including 'Part H'. However, when one looks at 'the requirements of Part H', if one ignores those relating to septic tanks, cesspools and 'building over sewers', the only 'requirements' seem to be that 'there should be provision for' disposal of foul water and rain water. Nothing else!
So, I'm not sure where that leaves us. There are all sorts of things said about plumbing work and LABC - some, like you, saying/believing that some things (like above-ground drainage) are
not notifiable, and others saying/believing that some things (like installing new loos etc.)
are notifiable - but in neither case can I work out where those beliefs come from.
"where the work does not include any work to underground drainage, and includes no work to the hot or cold water system or above ground drainage, which may prejudice the health or safety of any person on completion of the work".
Did you involve LABC with your tap replacement?
Of course not, any more than I intend to involve LABC in what we're talking about here - but, as above, I don't know whether that is 'correct' (per 'rules'/laws) or not!
Mind you, I've highlighted above the bit of the statement that you forgot to also highlight
Having said that, if you recall that discussion about my tap turned into a many-page debate when someone jumped in and suggested that if I replaced the tap without including a check valve, I would be contravening regulations and putting people at risk of Legionella infection - so maybe, in their opinion, "prejudicing the health or safety of any person on completion of the work"?!!
