Romans helped design the space shuttle
  • Thread starter Thread starter JP_
  • Start date Start date
JP_
17 May 2012
The US standard railroad gauge (distance between the rails) is 4 feet, 8.5 inches. That's an exceedingly odd number. Why was that gauge used? Well, because that's the way they built them in England, and English engineers designed the first US railroads. Why did the English build them like that? Because the first rail lines were built by the same people who built the wagon tramways, and that's the gauge they used. So, why did 'they' use that gauge then? Because the people who built the tramways used the same jigs and tools that they had used for building wagons, which used that same wheel spacing. Why did the wagons have that particular odd wheel spacing? Well, if they tried to use any other spacing, the wagon wheels would break more often on some of the old, long distance roads in England . You see, that's the spacing of the wheel ruts. So who built those old rutted roads? Imperial Rome built the first long distance roads in Europe (including England ) for their legions. Those roads have been used ever since. And what about the ruts in the roads? Roman war chariots formed the initial ruts, which everyone else had to match or run the risk of destroying their wagon wheels. Since the chariots were made for Imperial Rome , they were all alike in the matter of wheel spacing. Therefore the United States standard railroad gauge of 4 feet, 8.5 inches is derived from the original specifications for an Imperial Roman war chariot. Bureaucracies live forever. So the next time you are handed a specification/procedure/process and wonder 'What horse's as came up with this?', you may be exactly right. Imperial Roman army chariots were made just wide enough to accommodate the rear ends of two war horses. (Two horses' ases.)  Now, the twist to the story: When you see a Space Shuttle sitting on its launch pad, there are two big booster rockets attached to the sides of the main fuel tank. These are solid rocket boosters, or SRBs. The SRBs are made by Thiokol at their factory in Utah . The engineers who designed the SRBs would have preferred to make them a bit fatter, but the SRBs had to be shipped by train from the factory to the launch site. The railroad line from the factory happens to run through a tunnel in the mountains, and the SRBs had to fit through that tunnel. The tunnel is slightly wider than the railroad track, and the railroad track, as you now know, is about as wide as two horses' behinds. So, a major Space Shuttle design feature, of what is arguably the world's most advanced transportation system, was determined over two thousand years ago by the width of a horse's as. And you thought being a horse's as wasn't important? Ancient horse's as*es control almost everything.
I saw this on fb, have not verified facts!
I seem to remember that being on What The Romans Did For Us, about 40 years ago.
  • Thanks
Reactions: JP_
When I briefly worked in the Railway industry, one of the enthusiasts told me that UK rail track had recently been widened by an eighth of an inch, so that the flanged wheels would have a little more slack and run quieter and more smoothly. The change had taken place over years, every time sleepers or tracks were replaced, they would be put at the new spacing. The way wheels wear, they tend to centralise on the rails so the flanges do not quite touch the side of the rails.
BTW, the traditional rail track, in Imperial units, is correctly expressed as "four foot, eight and a half inches (4' 8½") and not in decimals as 4' 8.5".
I mostly worked at Darlington Low Level, which is significant in Railway history, and older than Bank Top.
  • Thanks
Reactions: JP_
Wheels do not wear to centralise themselves, they are designed that way.
They used to be made flat, but wear to that shape, which runs better, so are now made that way.
The inner flanges are a safety feature only, and do not normally touch the rails.
I too had always thought the flanges kept the wheel on the line, but I asked a retired (now deceased) steam engine driver, friend about it, and had it explained to me as above, that the wheels form a slight cone.
