13-year old Ideal Logic+ 24 (Combi) has regular pressure problems so I regularly top it up. Recently, it's not giving me really hot water, just warm, even though the controls on the boiler are set to maximum for both water and heat.
The other day I stopped getting warm water and noticed the pressure was too high, between 2 and 3, and the arrow just vibrated there. I bled the radiators and got the pressure back to just above 1. Then reset the boiler and set it in winter mode. The boiler turns on, the burner lights up when I turn on the hot water tap, but in a minute turns off and I get either lukewarm or plain cold water at the bathroom tap, right next to the boiler. The radiators are not heating up either.
The boiler message is "No water flow lockout" (once followed by "No water thermistor", but this disappeared on future resets). Then the boiler cycles though these messages: 1. Fill system to 1 bar; 2. Bleed radiators; 3. Check radiator valves open; 4. Reset boiler;
What could be the issue? And could anybody check if all the valves are correctly positioned?
Or could this be an issue with the Nest thermostat the previous owners linked to the boiler? I set it to manual and only use the boiler controls.
