I’m trying to fill a 50 m deep hole in old plaster so I can rehang a curtain pole. I’ve used ronseal big hole filler and left it for 4 days but after drilling and putting plugs in I can see as soon as I put weight on bracket that the plugs are pulling out
What about screwing a wooden batten to the wall using new hole locations and then screwing the pole to the batten. You could make it blend in a bit by routing the edges.
