- Joined
- 16 Oct 2021
- Messages
- 663
- Reaction score
- 72
- Country
Having made some pipe diam changes over the summer I thought it would be a good idea to fill the system and check it, ready for the winter.
On filling the circuit I noted that it seemed to be taking longer than usual to fill so checked for leaks and started to refill again.
Got the circuit to pressure (1 bar) and then watched it drop to zero within seconds so must be huge leak.
Now I can access all of the heating pipework and have checked..no leaks, no water
I then check that the external release value was working (I have a quarter turn 22mm value that dumps the circuit water outside) but there was no water at the valve so a substantial amount of water is being lost but I have no idea where.
I have checked the pressure relief value by closing the circuit values and over pressurising the combi so I know that works.
My only guess is that the filling loop non return valve is now letting the circuit pressure go into back flow but as the incoming pressure is 5-6 times higher that the circuit pressure I doubt it could get back.
Any suggestions for the next round of diagnostics?
