I am building a small lean to shed 3m x 60cm on the side of my house. It will have a slight slope along the 3m length. I am guessing that it will drop around 5cm over this distance. Can I grind out a diagonal line across the bricks for the led flashing or should I be stepping the led as I work across this decline? The former seems a lot simpler as the led doesn't need to be cut or stepped but not sure of the drawbacks, if any.
Thanks in advance.
Thanks in advance.
