If the testing results show major fault on the motor, could the PCB board be the issue ?
If there is major fault on motor, then the motor needs to be replaced majorly. Since the motor runs, fault on it is improbable.If the testing results show major fault on the motor, could the PCB board be the issue ?
Machine has no display, just buttons and leds.
Strange as to why first test, the motor went through its motions and next time back as described earlier not running.
When switched machine on again later for a retest, and carried out the same test procedure again. The motor did not run and the fault was back as described in my posts.
