Hi, I currently have an old boiler (regular) that is playing up, so I am looking to get it swapped out.
I have briefly talked to a plumber who thinks I might be able to get away with a larger combi, and as a whole, I agree, but I suspect this situation will change.
Bedrooms: 5
Radiators: 17
Bathrooms/Showers: 3 (all showers are currently electric)
Bath: 1
People: 2/3 adults, 2/3 kids (a parent visits for months and one kid is only here at weekends)
At some point in the future (within a couple of years) I would like to swap out at least one, but perhaps two of the showers to run from the hot water supply. The kids are still young enough that we are supervising them while they wash, so only use the bath/shower one at a time, but I suspect there are only a couple more years of this.
The combi boilers that I have been looking at have been the Viessmann 200-W 32kW and the Worcester Bosch Greenstart 8000 50kW. These 2 in particular claim to have flow rates of 17l/m and 18l/m respectively. Are these numbers accurate? (I tend to be sceptical about marketing literature) and would you realistically be able to run 2 showers from it comfortably?
The current system uses a vented cylinder, but I have done a fair bit of reading on the unvented (indirect) cylinders and their ability to provide mains pressure hot water for the showers, and I wouldn't be limited to the low flow rates of the combi. These appear to cost more than £1200 for anything of a decent size, which when coupled with a new boiler becomes fairly pricey. Is it going to be worth the expense to fit the unvented system? How much hassle/expense is it to replace the vented system with this?
My main interest in the Viessmann is the modulation and the reported quality. Assuming I go with this brand, do you need to have a Viessmann trained installer to get the warranty (7 years)? I have checked for local installers, but there are not many around my area, and getting any plumber can be difficult at the minute, so narrowing it down to a subset is not likely to help me find anyone.
Open to other ideas and suggestions on this system.
Bedrooms: 5
Radiators: 17
Bath: 1
