Hi All,
I know this topic has been done to death but I’m looking for a definitive answer there is so much conflicting advice.
I want to insulate my loft there is already some insulation in there which I plan to remove but I don’t want to cause myself problems down the line.
(Old Victorian property - solid walls with no insulation - slate roof)
My thoughts…
Add 25mm batons to the joists flush with the plasterboard.
Fill the remaining space with PIR board - I think it will be 50mm this will bring the boards flush with the joists taping the edges with gappo tape to ensure a tight fit between the joists.
Then add 100mm PIR boards laid across the joists (may use thicker if funds allow).
Then tape the gaps on the top layer.
I appreciate this may be a more costly approach to take than just using insulation rolls but I’m trying to do belt and braces - bedrooms can be freezing.
Can anyone definitively tell me that this is the right approach to take?
My thoughts…
