Well done you! I nearly suggested that pipe, but couldn’t work out the dogs dinner of pipingI have now fixed the problem - in the picture there is a 22mm pipe capped off, this was actually the HW feed to the en-suite mixer.
The far right 15mm is the connection back from the mixer(Hot) I have connected these together and all is now working.
Bit of a head scratcher but got there in the end.
Disgusting pipework.Think I may have found the issue - plumber hasn’t been back out yet but I’ve had a look where the cylinder used to be and the 4 x 15mm pipes are all connected together. Am I right in thinking one of these used to feed the hot water and is now connected to the cold mains supply?
Could it be my hot feed to the mixer is actually connected to both hot and cold supply now and obviously the cold mains is greater pressure so it never gets hot?
