my full thought
now you talk about tv and boarding 100% insulate
it allows you to use it in the summer when sheds tend to overheat my shed fully insulated can still reach 30 degrees
you may not mind the cold but others may enjoy some warmth so you have the option
in general an insulated shed at say 6 degrees can warm with a 1kw setting to perhaps 10 or 12 then slowly cool over the next 3 or 4 hours
in my shed i sit on my workmate the fan heater is hung from the ceiling and aims to where my head is about a metre away and the phycological comfort is as good as 10 degrees
if i am doing any gluing on woodwork i go for 12 degrees at glue can go white or even not set properly at below 8 degrees
the last point more to illustrate things you may not have thought off
and as an aside some fridges or freezers will not work well below perhaps 12- 15 degrees
