Wired electronic door chime and illuminated 2-wire push switch
18 Apr 2022
Is this ever likely to be a viable combination, or shall I give up looking and have a traditional solenoid operated ding-dong sounder?
Did not have an illuminated push switch, but 20 odd years ago had an electronic door chime, with two push buttons one for back and one for front door, and a second speaker.
But today all the wireless options, and video type means no one seems to want half way options, either wired with video or wireless.
I have since moving into this house only a few years tried many options, buying cheap Lidi to start with, a pair so one button worked two sounders, latest is TP-Link again two sounders on one button, and it logs when rung on phone.
But it seems the old door bells have vanished.
Well I want wired, and I want an illuminated push, and there are still old-skool bells about, some actual round bells, some the enclosed sort with a solenoid and a rod that bangs into a couple of bits of old xylophone, even some with the long dangly brass tubes.
And electronic sounders, which I'd rather have (although I shan't be selecting Colonel Bogey).
But problems with no solenoid coil for current to reach the bulb, and/or the bulb providing a good enough connection to trigger the electronics....
With modern electronic door bells a two wire illuminated push button may be possible by using a resistor to simulate the coil that a mechanical sounder has.
But simpler to use four core cable to separate light circuit from switch ( push button ) circuit
Touch-sensitive,with LEDs
I've not opened it, but I suspect it would be a non-trivial task to separate the power for the LEDs and the touch-to-close function.
A brainwave has just broken on the shore of despondency (actually, that's an exaggeration. I'd prefer an electronic chime, but am not strongly opposed to bits of old xylophone):
Have a 12V relay - use the button to work the coil and the contacts to switch the chime.
Is a transformer next to a relay likely to affect the operation of the coil?
Are either likely to affect the operation of an MCB if mounted next to it?
