Lead flash under window sill condensation?
6 Mar 2016
Hello
Recently had my loft converted and there is a damp patch in the corner of the window. I popped one of the glass panes out and did a better job of sealing between the lead and the window sill on the outside (there were one or two small gaps).
However the damp still seemed to be occurring so I pulled the sill off to look underneath and the plaster board was all mouldy (it’s a few months old). Left it now a few weeks and it appears that the lead is getting lots of damp condensation on it.
I’ve attached some photos but would be interested to know the best way to proceed?
Is it likely to be condensation causing the damp patch?
Do I trim the lead back to the sill on the inside (overhanging currently on the inside by 50mm or so) then seal the gap flush to the sill? Do I put some sort of expanding foam insulation in the gap rather than plasterboard directly on top of the lead? Any other ideas?
Would contact the loft company but we’ve fallen out due to a plethora of shoddy work they undertook.
Thanks in advance!
BH
What is the window frame sitting on, a wooden frame, an opening in brick? Can you put up some pics from outside showing the treatment of the window.
Blup
Hi Blup and thanks for the reply. The window is sitting on the lead and the lead is sitting on a timber frame. I’m the photo you can’t quite see this but the timber frame is 99% covered by the lead, after the lead what you can see is the top of celotex board before plasterboard has been attached through that. I’m attaching a photo of what is under the sill.
I can’t get a photo outside until I’m home in the day light which will be Friday.
BH
The lead is wrong.
the purpose of the lead is to act as a tray and it should be turned up the window frame on the inside so any water penetration can’t run inside.
being flat the lead is simply creating a flat ledge for water to come in.
up the sides there should probably be a vertical DPC protecting the plasterboard from the outside - it looks like the plasterboard touches the lead.
minor failures on damp detailing are the main cause of damp appearing on plaster.
Is the insulated studwork under and around the window properly ventilated? Its 50mm for a cold roof, dont see why the requirements should be that different for vertical studwork. Without that the warm air gets trapped and condenses inside the frame at the nearest cold spot. The other possibilty that comes to mind is that it got soaked in rain water before it was finished and needs to dry out.
Your suggestion might be worth trying because it would be relatively easy to remove, but I would be cautious about chopping the leadwork as it might loosen the remaining part.
Blup
The flashing should be like this:
full
Thanks. I have just had a very expensive lengthy (4m) wall-side wooden window/door built in on my balkon. The roofing company (3 different companies) insisted on replacing the whole window because the original one (still in excellent condition) was mounted too low and they had to re-cover the wooden deck of the balkon. They did not want to work and give warranty on roofing work if the window frame is not raised up.
So, after the old window frame and everything was demolished, they (window making company) installed a wooden beam (like 10 cm high), in full width of the balkon, between two side walls (brick, terrible state, from 1909), and they wrapped that wooden beam with bitumen hydroisolation layer, that they fire-welded to the existing bitumen hydroisolation in the front (on the balkon itself). They planned to cover the rest with new bitumen, over the old bitumen, after the window installation is completed.
Then, before the window was posted on that bitumenised wooden beam, they (roofing company) put lead stripe, which is just "L" shaped - so compared to the photo you put, there is no upstand in the back. I am not sure how deep the lead is seated underneath the window frame. And nothing on the sides (there are side walls, and space between the window frame and side walls was filled in with polyurethane foam from the inside of the room).
They ran into problems with filling it with foam and even did not fill anything from outside, they (window making company, not the roofers) just left saying they will come another time to seal the outher side. As they were not coming, I have sealed it with best polymer based sealing material I could find.
I thought what is the purpose of the lead as that balkon is extremely wet, from rain and from dew, they said it is ok what they did. I think it would be better to seal with modern kit instead of lead, as the capillary water will for sure find its way inside between the lead and the wood ?
Further development - and I am devastated - is that contrary to what roofing company said - that the water will be evacuated completely from the balkon deck after they remove the massive floor that was on top of the deck (and I realised afterwards that the floor was there only to cover the poor work and massive reataining of water, work done by previous roofers who made the balkon 10 years ago) - the water is staying (a lot of water as the slope of the deck is not good). They said they can't do anything and that the water will always stay. I stopped them and I am trying now to find a solution for the replacement of the balkon deck.
Does that lead flushing have any value and purpose at all?
I will post photos, the DIYnot site seems to have problems right now.
You don't normally have a lead flashing on a door, however you do normally have a projecting cill that overhangs the upstand (which you don't have), then some sealant is used to seal the junction underneath between the cill and the upstand.
The roof should be falling away from the door to wherever the drain is, there should be no pooling. What was the point in them insisting on an upstand if they never sorted out the falls?
BTW you should have started a new thread in the Roofing section really.
Thanks I also think the lead will just attract water and make the wooden frame rot faster. I'll put some polymer kit there in any case, I think it would better serve the purpose. It is difficult to impossible to get good service in this building and renovations area here, unbelievable.
Finally after a long winter, roofing company replaced the deck and it looks now like below. They still need to complete the gutters and hopefully this stays well at least few years....
