Newly fitted light switches trip the breaker. (Ed.)
28 Nov 2023
Hi, I have two wall lights in a bedroom. I am currently fitting the switches. There are to be two switches one under each light. When I began to fit the first switch, I connected the wires to the switch unit and the lights came on. But when I go to switch off the light switch it trips the fuse in the consumer unit. Any ideas why this happens? Could it be because the second switch isn’t connected yet? Thanks .
I’ll take some pictures and post them. Basically I connected the live wire to the top of the switch unit (labelled 2) the neutral I connected to bottom left of the switch unit ( labelled 1) then with the earth I connected that to the screw that is on the metal front plate of the switch. As I say the light comes on but when I flick the switch to turn it off it trips.
I’ll take some pictures and post them. Basically I connected the live wire to the top of the switch unit (labelled 2) the neutral I connected to bottom left of the switch unit ( labelled 1) then with the earth I connected that to the screw that is on the metal front plate of the switch. As I say the light comes in but when I flick the switch to turn it off it trips.
If that is in fact a neutral, it will cause the trip. Turn the power off, remove the 'neutral', and terminate it separately, in something like a connector strip. Reassemble, power back on, and test again.
Thanks Harry. Where should the neutral go then within the unit? I’m attaching a pic of the unit.
switches do not have neutrals , unless remote/wireless switches - they may have a black or blue wire - but that is still live - if there are any neutrals they may simply be connected together separately
Is this a new installation you are setting up ?
Send a picture of the wiring behind the switch.
I assume the neutrals should just be connected together.
If it is a neutral, then nowhere in that switch. As said, isolate it in a connector, see if everything works as normal. If not, come back here.
This is a pic of the wiring. I’ve just capped them off for now. The cable will obviously be cut shorter eventually.
How is it connected at the other end?
If the blue is neutral, you can either wire the switch to either do nothing, or put a short on the supply and take out the fuse....
It’s a wall lamp see pic. Switch will go directly below it.
