Good morning, the boiler had tripped this morning with low pressure and the gauge shows 0.6 bar. I’ve turned the boiler and the underfloor heating pipe valves off but, I’m beginning to be concerned that there might be a leak of water from the system so after re-pressuring the vessel, assuming that I can do that with a tyre pump and the pressure can be checked using a tyre gauge. I’ll re-fill with water to 1.0 bar and with the isolation valves off leave it for a couple of hours. If no leak then open the isolation valves and do the same thing. Hopefully there are no leaks.
Certainly do not want to contemplate ripping up the floor to get to the John Guest couplers.
Jethro
Jethro
