Slow down ... not sure if you remember (read back on the posts) but I mentioned that to using a pressure tester to clear blockages/restrictions was a last resort and that you really need to get to both ends of the pipe that way the pressure can be built specifically in the pipe that's restricted and then used to blow through it under pressure. Now that the pipe is flowing then it's not blocked anymore rather restricted and that process may not be as effective. Even then you don't want to put the whole system under that pressure especially if it is gravity fed. When I recommended the pressure tester was when there was little or not flow. That has changed and now there is flow so the tester may not be needed now and the cleaner may be enough.
If you can work on that pipe specifically then that would be the way I would go.
