My new Vaillant Ecotec Plus 637 system is cycling constantly, despite reducing flow temperature and adjusting settings.
Details of the system
Vaillant Ecotec Plus 637 boiler
250L megaflow water tank
6-port manifold underfloor heating (4 ports as 1 main zone + 2 individual zones) coverage an area of 85sqm,
8 radiators + 2 towel rails
My installers recommendation was to leave settings as factory default, the UFH mixer on max but my installer doesn't pay my energy bills. I tried to get a couple of other engineers to look at this but had plenty of no-shows and decided to take it upon myself to try and sort this out.
Using advice given to previous users on here with similar experiences i've been changing setting but find boiler keeps cycling (egg timer flashing).
I've
Reduced flow temperature to 65°C
Water tank temperature below 62°C
Manifold mixer set to 45°C
D00: 20kWh
D01: 8 minutes
D02: 5 minutes
The boiler runs steadily for 5 minutes around 49°C (flow temp D40 at 49°C, return temp D41 at 44°C). The manifold feed temperature reaches a little higher than 45°C, while the manifold return is just over 30°C then all of a the boiler significantly increases flame, driving flow temperature to 70°C and triggering cycling behavior.
Would be grateful for advice on how best I optimize it for efficiency and stop the annoying cycling?
I've
D00: 20kWh
D01: 8 minutes
D02: 5 minutes
