- Joined
- 27 Sep 2022
- Messages
- 303
- Reaction score
- 23
- Country
My viessmann heat only boiler 13kw (OV) is running at flow temp of 54.5DegC and a return temperature of 40DegC. I know it is a crude way of getting the return temperature on boiler. In the 2nd picture showing the return temperature you can spot the sensor attached to return pipe next to filter.
I have following Rads heating 4 bedrooms and 3 baths. These T50ratings were taken from Manufacturer's catalogue.
I have logged m3 consumed from gas meter running only boiler for 1 hour.
Boiler was in steady state (meaning it was on for the last 3 hours)
In 1 hour of usage it ran for almost 50 minutes and consumed 0.625m3 X 10.8 = 6.75kwh. CH dial on boiler is just below 4
Flow temperature on boiler was 54.3 DegC and a return temperature of 40DegC.
I am running boiler at 54.3+40=94.3/2. Thermostat is set at 19 DegC (and is installed in the coldest area of the property; lounge which was not heated during this time) so my radiators are effectively rated at 28.5DegC, Correct?
This means my boiler is only 55% efficient, I don't understand, there must be something wrong somehere, Could someone please advise what am I doing wrong.
Flow temperature dial is set just below the delivered condition (pic 3). It used to get to 49.5-50DegC at this setting and would turn off at that temperature. Outside temperature has dropped couple of degrees due to a cold wave during the last couple of days (where I live).
Edit : Pump is external and is at C2 setting (medium) Flomasta CP50 (6m head)
| Rad | T50 Rad output kw | T 28.5 Rad output kw |
| Bedroom GF | 1.3 | 0.64 |
| Bedroom UP | 2.08 | 1.03 |
| Bedroom 2 Up | 1.56 | 0.77 |
| Guest Bed | 1.10 | 0.54 |
| Bath 1 | 0.80 | 0.39 |
| Bath 2 | 0.70 | 0.35 |
| Bath 3 | 0.65 | 0.32 |
| CH Load kW | 8.19 | 4.04 |
@1800 hrs on | 8096.04m3 |
@1832 off | 8096.48m3 |
@1843 on | |
@1900 hrs kept running till I logged the meter | 8096.74m3 |
