Immersion timer No power on Switch but clock working
2 Feb 2009
Oxfordshire
Hi all
I really hope some one can help please ?
I have a timer on my day time immersion heater switch.... the clock on the timer is working but the switch on the wall isn't (no red light when switched mis turned on)
I have attached a picture showing the issue.
I have checked the fuse board downstairs and the fuse hasn't tripped out and is showing as on..
Would be grateful for any advice.
Many thanks for any help and your time.
Kind regards
Mike
Thank you for the reply...would there be an internal fuse within the switch ?
Picture attached was when it was working :)
Could the clock be battery powered? Check for a loose/burnt wire as suggested.
Neons do fail, I have seen many a neon not working, but the switch or socket is still OK. I have an easy test Testing for live.jpg my meter has a non contact test, so all I need to do is hold it close, what makes you think the immersion is not working other than lack of neon? And what have you got to test with?
But it goes to programmer first, I have found with central heating doing water heating the water will stay hot for a few days, but with the immersion heater if no sun that day, water goes cold, as immersion does not go low enough in the tank, so would assume with peak and off peak likely the same, and if peak stops working it could be years before you realise it has stopped.
So only easy way without a tester would be to turn off peak off for a few days and see if water goes cold, or run a bath. But a simple non contact tester means far easier to test without waiting a couple of days. These 1705941847666.pngseem to be liked by the DIY person, and in this case a good way to test.
It's probably just the neon indicator light that has failed. (Unless its a led in modern units?).
Need a wider picture to be sure the day switch white cable goes into timer lhs and the yellowed wire off to the immersion element... but that's the only logical way to wire in a timer imho.
That the timer lights and works would mean the immersion should work, too.
Many thanks for all the informative replies.
I think its more than just the noen light as when the switch is switched to on... the buttons on the timer like boost still don't work when pressed
Thanks again
Mike
