Hi all,
I have got a new Vaillant EcoTec 418 installed recently and noticed that the set hot water temperature is being ignored, instead it gets generated by flow temperature. Also diagnostics menu says that DHW hours are 0.
Could this be a result of an incorrect wiring? I'd like to set DHW and radiator temperatures individually.
System is sealed, which has a Megaflo CL145S tank with 2 electric valves and 1 pump controlled by a 2 channel Wiser room thermostat kit.
Thanks in advance.
Thanks in advance.
