I've done a lot of reading here on similar threads and think I know what's up but I would like to double check my understanding.
Recently the overflow pipe from the feed tank that tops up the central heating loop has been leaking into the garden. The water is black which suggests corrosion. I checked the tank and there is warm water in it (not hot enough to melt the tank - i've read those stories and am aware).
There is a lot of air in the system as evidenced by the whooshing etc.. noises that happen when it's on. I suspected that the expansion and contraction of that air when the heating goes on and off might be causing volume changes which is pushing water back into the feed tank and causing the overflow (I stood and watched the tank and could see a water upwelling just after I heard a lot of gurgling)
I turned off the valve that leads to the ballcock in the feed tank to see if either its that which is replenishing the water or if (worse case scenario) fresh water was potentially coming from a cracked/leaking coil in my domestic hot water cylinder into that loop.
At first the water level in the feed tank dropped which seemed like good news - but today after heating both radiators up and also domestic hot water I see the level in that tank is back to overflowing and that extra water is not coming from the ballcock filling mechanism.
Is there anywhere else the water can be coming from? It seems like a new cylinder for me but I just wanted to run it past someone before I find a plumber to fit me a new cylinder (or maybe go to a combi boiler).
Cheers
Cheers
