- Joined
- 11 Dec 2012
- Messages
- 5,774
- Reaction score
- 3,157
- Country
All impressions, rather than timed.....
I've often wondered if sinks and baths might drain faster, were it not for the fact that once the plug is removed, the water begins to swirl, as it progresses down the plug hole - drawing in air, and sometimes even more air via the overflow....
Whether by luck, or design, our bath has always been reasonably quick to drain, but always accompanied by lots of swirling, and air sucked in at the overflow - when fitted with a normal, bath sized plug. I recently needed to swap the plug, so decided to fit a pop-up type. The pop-up, at a guess restrict the outlet area to around 50%, so I anticipated it might double the time it takes to drain the bath. In fact it appears to drain (at least initially) somewhat quicker than it did before. The water no longer swirls as it nears the plug hole, the suction of air via the overflow and glucking has stopped. Only once the level in the bath has reduced to the final inch or two, do it appear to drain slower.
My conclusion - Obviously, the swirling, flings the water out and away from the plug hole, slowing the flow.
You could blame it on brexit i suppose?
