Pyronix v11, new router, "internal wifi comms fault"
What about if you push No after pushing D and then entering your code, so
D
Code
Upon error, push no.
I’ve just tried what you described on my test kit and it doesn’t replicate what you’ve said
V11? Can't say what software version.
I'd video it but not sure I can upload files.
Yup…. I’ve also tried it on a v10 panel in case you posted the wrong software version
D
Code
Goes to 'Set system'
Resting
D, eng code
Active faults | int wifi ...
No
Set system
No
Force arm on 1st ...
No
Enforcer time.... full circle?
And if you go from Home Screen and enter code and then push no when you get the error you just go full circle?
If so then I’d suggest the power cycle as suggested.
Please tell me how a power cycle will reset the router IP and SSID?
I can't see it.
Cycled the mains (ignoring the int battery)
No change in status.
Solved? (so far)
Power cycle.
User code
No
! Provided access to the menu which includes set up wifi.
Now to try and follow the ... poor sequence to set via a smartphone
#failed 3 times previously.
Thanks for your help @DIYSOS2018
I've not meant such a confusing and illogical MMI as this.
I shall try.
