Would you mind using it to calculate the EV size required using the above with the following conditions.
System volume 150 litres.
Flow temperature 70C
Return temperature 60C
Mean temperature 65C.
precharge pressure 1.0 bar
Filling pressure 1.5 bar.
Diaphragm Type inserted bladder
Thanks but my own basic calculation has worked fine for me for years, when I used the Flamco calc it came up with something like a 30L EV, My calcs above, show that a 14L will result in a final pressure of 2.31 bar.
A 8L EV with pre & filling pressures of 1.0/1.5bar will have a final hot pressure of 2.5bar with a system volume of 83L. If the pre & filling pressures are both 1.0 bar the final hot pressure will still be 2.5bar with almost double a system volume of 157L.
Some do specify both pre pressure and filling pressure, others don't and you can see why.
