- Joined
- 13 Feb 2024
- Messages
- 34
- Reaction score
- 1
- Country
It has a bottle air vent.Assuming the heat store is "vented" then its a bit surprising that there isnt a vent of some sort (even manual) from the top of the store.
It doesn't collect much gas (being near the bottom of the system). But I do vent it periodically. I do not believe this is the issue.
Not normally.Do you get any air from the rads when you vent them even with LPG boiler on?.
I've had a few issues in the past (now largely solved) that lead to air or gas in the system. This conveniently collected in one particular radiator (downstairs!) that could easily be bled away.
There's no sign of collecting gas or air locks anywhere in the house system - it all works fine on the LPG.
It's possible there's an air lock between the house and the heat store, but it's not obvious where - all the above ground pipes travel horizontally or vertically upwards from the lowest point without any obvious places for gas to collect.
The underground pipe is basically horizontal. I suppose there could be a long arc? How would I check?
There are drain points at the lowest point in the cellar (~7.5m head from F&E tank). I've timed how long it takes to fill a 2 litre jug, without any pumps on, to check for obstructions in the pipes between the heat store and the heating system in the house:
The quickest (F&E tank > cellar drain ~35m) around 4 seconds.
The longest (F&E tank > cellar > heat store > cellar drain ~105m) around 30 seconds.
The timings are similar between flow and return pipes.
I'm not sure how useful these numbers are though.
Obviously coming 35m straight down the house is quicker than travelling 35m down and 70m horizontally. But 15s/litre seems pretty slow to me.
But I've not got any numbers to compare them to.
Do you mean the heat store data plate?Can you post a photo of the details on the heat store labels.
I've partially drained the system several times recently (see above. Also replaced leaking pump valve). It always fills quick enough.By unrestricted I mean that there is no blockage in this pipe, this can be quite common where its teed into the system, you could drain off say 5L or so and see if the F&E cistern starts refilling rapidly which will prove it clear.
Shortly before P1. So return?Is it teed into the flow or the return piping?.
I think so.If the Wilo set to C3 at 7.9M still only results in very poor circulation on bypass then it logicall has to be a restriction somewhere or air somewhere,
The cistern water is clear. I've recently replaced a radiator bleed valve, I've drained water out of the system from various points, I drain the Fernox TF1 annually.the condition of the F&E cistern if you look into it will give a good indication of a clean/dirty system.
Apart from the small debris collected by the magnet, there's no sign of sludge etc. Drained heating water appears largely clear (certainly settles clear).
