Radiators stopped getting hot - everything appears to be working.
Downstairs radiators now hot!
With the settings as they were last night
P2 & P3 - 1.0 m³/h 46 & 85 W (I checked, it was 46w, but that is with the P3 in series)
It took ~2½ minutes for the hot water to travel ~70m.
Once the bypass thermostat registered the hot water, it closed and P1 joined in.
I then had 1.2 m³/h with the Wilo (P2) running at 60w
That's with it set on UFH 6.8m
Try setting the Wilo to CC3.
The overall flow is reducing as the TRVs are closing
What setting should I have P1 on?
It can also do PP CP etc.
It's currently on CC2 but it would be good if I could drop P3 and have P1 & P2 adjust to the TRVs together.
Yes, of course, you have 3 pumps in series with the heating on, difficultse to say but obviously reduce P3 to say CP 6.5M or so to stop noise, P1, on CC2 is 5.1M, CP1 is 3.0M, CP2 is 4.5M & PP2 is 3.5M, you could just try PP2 but I think it will be too low, then CP1 at 3.0M and/or CP2 at 4.5M.
Have fun.
