Cupboard back missing below gas hob. .
20 Mar 2024
Can you have a back on the cupboard under a gas hob. As our fitter hasn't and no explanation given ,looks messy seeing all pipe work and old wall.
I would say so yes. Clearances are given for above and to the side of the hob, not below. Should there be a built under oven?
No just a cupboard with one shelf
Should have a back on it then.
I currently have an oven under mine and obviously, no back on it. Technically not a cupboard but a 600mm space. All my other cupboards have backs on them.
You can add a cupboard back. Preferably make it easy to remove, for access to any pipes/wires at some future date.
He couldn't be bothered to cut a little bit for valve access and let pipe through.
Fitter...
It seems as though they all differ from a full back to no back. Ours has a 6" gap below the hob and the start of the backboard and was built as a dedicated hob unit. Perhaps a standard cupboard is cheaper.
