could not to drop more than 80% in 8 years?
I do wonder then why larger inverters aren't fitted as standard in most domestic PV installations as surely this is quite a common problem ?
Purple is power in the battery or state of charge (SOC) brown is what I am using.The purple line seems to be capped at 4. What is SOC?
What is the brown line?
You mention a power cut. Surely your inverter will close down? Or do you have an off-grid socket for the freezer?
IF the OP wants to solve this "problem", he first question that needs to be answered is what is the topology of their solar/battery system? does each battery have it's own built-in inverter? do the batteries share an inverter with each other but not with the solar system? or does the system use one inverter to run both the solar and the batteries?He wanted to know if adding a third battery pack (of 2.4kWhr capacity) would allow him to boil a kettle without import from the grid.
Yes that was some time back, so yesSolar system was installed back in 2011
Seems to show not part of same inverter, theWere installed in Feb
is very different today, the smart meters actually measure what is produced, I wish I could get 60p per kWh I produce, I only get paid for what I export as 15p per kWh, and it may well be those on the old deals get no benefit from having a battery? I can't look it up as no longer available.we get just over 60p per KW we generate and then another 4p for half of that as deemed export, the panels paid for themselves in FIT payments in under 10 years.
That does not tie in with my solar panels, my kettle shows no movement of the smart meter. In fact only when having a shower does the smart meter show any import, the in house display (IHD) is next to useless as it only shows anything from 9 pm to 11:30 pm when it auto switches off.When I put the kettle on it used to draw around 3KW , but since the batterys were fitted its around 1-1.2kw we are pulling in from the grid
I did try to find details, it seems it is still 2.8 kW or there about, so uses same power to heat as my kettleit draws less power
both can save energy, but if they use more that the battery can deliver still means it draws from the grid. There are kettles designed for caravans which only use 750 to 1100 watts, however clearly they take longer to boil, my pre-solar method was to use two cup boilers in the TV adverts to made two cups of coffee and give time for other things. I now try to use one boiler twice so as not to exceed the time the adverts run, but not exceed 3 kW, since they only boil just enough that can still be done.
is an unusual over night power usage as intend to go out for a day or two, used 7.9 kWh over night, charging battery and doing washing. The in house display shows 9.44 kWh and cost £1.93 which includes standing charge. As to why the IHD and the solar software do not tally not a clue.If you need to find a tradesperson to get your job done, please try our local search below, or if you are doing it yourself you can find suppliers local to you.
