- Joined
- 29 Sep 2022
- Messages
- 95
- Reaction score
- 6
- Country
My first time doing so. The place hasn't had a flush in years. It's a system boiler with indirect invented cylinder. Is it possible to use the mains fill to flush the system out? So far I know to turn everything off and manually open the 3 and 2 port valves. But what valves should I close and where should I drain from?
It's in the garage so the bottom drain points are the lowest. I was thinking to just close off the flow and return by the boiler, and use the magnetic filter drain point while opening up the fill, would that work? Thanks
