- Joined
- 4 Sep 2022
- Messages
- 625
- Reaction score
- 3
- Country
I bought one of these
www.screwfix.com
It is a 3/4" BSP nut and bolt though the tank side with a washer included and a 7/8" compression fitting on the other end ( though they cant seam to be bothered in listing this info in there description of there item)
any way the tank i made is from one of those 20 litre plastic transparent water drinking bottle that you see in all the snoot hoot hoot mega corps with free money to burn woke offices
I bored the hole TDC at the bottom of the drum and fitted the 3/4" tank connectors thread though the hole and inserted the washer first, then the 3/4" nut though the top of the bottle and got washer though threads then onto thread nut onto bolt as tight as what would seam like it wont snamp and tried it
Anyway with tank filled with water and it leaked! drained water and threaded it a little tighter and it keeps slipping and making a popping noise and going loose ever time i turned it 360o. so it must be slipping on the thread
Taken it appart and nothing has snapped so why will it not compress like a tank connector should?
A
McAlpine Straight Overflow Tank Connector White 22mm - Screwfix
Order online at Screwfix.com. Suits 19 / 23mm overflow pipe. FREE next day delivery available, free collection in 1 minute.
A
