Replacement shower quadrant screen
3 Feb 2010
Manchester
One of the sides of the shower screen shattered and I'm looking for a full replacement unit as it looks like you cant get just one section. I know the tray is 900x900mm but unsure is all quadrants are the same size and would fit or if I need additional measurements to get the correct one. Any advise?
What make or model do you currently have, pics might help if you do not know. If you have the type that has 2 curved sliding doors they can be repaired using perspex.
I think the brand was Roman based on some paperwork I have form when it was fitted (nearly 10years ago). Its the side glass that's broken, the two sliding doors are fine, but I'm happy to replace the whole enclosure, however, Roman seems to be quite an expensive brand compared to some others, hence asking if 900x900mm quadrants are interchangeable.
Sorry when you mentioned quadrants I imagined you are talking about a curved shower screen.Can't you get a piece of toughened or laminated glass cut to size at your local glazier
