- Joined
- 28 Mar 2024
- Messages
- 27
- Reaction score
- 0
- Country
Hi, After getting great success from this forum regarding fixing my very old Firebird boiler I was hoping that someone might be able to recognise the valve on my AGA that is at least 35 years old. I want to adjust the min flow rate as it is still running too hot at the lowest setting. When I had it professionally serviced (again for the first time in 30 years) the engineer said that the screw was the rusty one just beside the control know (with a red mark in the photo) and to turn in anti-clockwise. I have turned it 180 deg but the is no change and it is very stiff. Looking at a photo I took when the cover was off there appears to be a much more likely candidate in the silver screw that is resting on the rusty lever that is attached to the rusty screw. I have looked at loads of BM valve photos and manuals but cannot find one relating to this valve. Does anyone recognise the valve and if so could you let me know the name of the valve and which screw I should turn (and in what direction) to make the AGA run cooler at its lowest setting. Many thanks in advance. Michael
