- Joined
- 26 May 2024
- Messages
- 21
- Reaction score
- 0
- Country
Hi, New here and this is my first post. Over the last almost year I have been renovating my first home. On the side of the house is a small extension that has a single skin brick wall half way up and then timber frame the rest until a tiled roof. There is no insulation and the room gets very hot and cold.
I ripped the old rotten tongue and groove cladding off the top half and put a breather membrane and feather edge cladding to the exterior. I am now wanting to insulate and plasterboard the inside to help stop the extremes in temperature. the space will be used for coats and shoes etc as well as somewhere for our cats.
The area isn't going to be here forever as I plan on knocking it down and extending the house at some point down the line but for now want something somewhat pleasant.
What is the best insulation to use on the walls? I have a stud wall effectively to put the insulation in which is 100mm deep to the membrane. the brickwork has nothing and just a single skin, do I line this to stop damp and put something on it, either straight plasterboard or insulate this?
The roof is also similar but I have some insulation roll left I can put in here and board over. the walls are my main concern and can't seem to find the best solution or insulation to use.
Thank you in advance.
