Ok thanks @Madrab. So all in all there is nothing wrong with the system apart from the boiler going into DRY FIRE. Could the incorrect/stuck 3 port valve cause the flow/return reversing or no flow issues at the boiler or is it an air lock that could do that?
But then still the boiler works fine heating up radiators and hot water when manually operated with the actuator head off. Baffled...
