- Joined
- 17 Jun 2024
- Messages
- 7
- Reaction score
- 0
- Country
Hi
I am in the process of buying a house and the survey has raised an issue with the extension roof.
It suggested the roof tiles (redland 49) might be the wrong pitch for the roof (18 degrees) however a roofer has since told us thay this isnt an issue but the roof has failed and needs entirely replacing due to bad (uneven) brickwork and a broken concrete board that was propping up the tiles as well as a need to replace the sleeve arpund the drainage pipe.
However not sure if this is significantly overestimating the issue, is it possible to tell what migjt need doing from the attached photos?
As far as i am aware there has only been a leak in the house due to the seal on the drainage pipe.
