Token insulation in the loft, is not the same as bringing the walls and floor up to modern standards.Responsible, legit landlords can't get away without insulating these days
Nonsense.I saw on the local news, where they were saying about bad private housing, damp etc.. They chose to show film of the damp in one home, which was genuinely horrific - black mould growing in the room corners, black mould growing directly above a radiator. All very obviously the result of the person living there, creating lots of moisture in the room, not allowing any ventilation, and the mould at the radiator due to the wet radiator, never being heated. Why blame the owner, renting the property out, when it's the tenant obviously causing the issue?
No kidding.Insulating alone won’t get rid of the moisture that humans breath out,
It makes good TV and is easier than investigating .I saw on the local news, where they were saying about bad private housing, damp etc.. They chose to show film of the damp in one home, which was genuinely horrific - black mould growing in the room corners, black mould growing directly above a radiator. All very obviously the result of the person living there, creating lots of moisture in the room, not allowing any ventilation, and the mould at the radiator due to the wet radiator, never being heated. Why blame the owner, renting the property out, when it's the tenant obviously causing the issue?
You can deal with ALL the cold wall/floor/ceiling surfaces in house with insulation. You can only rid specific areas of (moisture) in a home using mechanical extraction and ventilation.And that isn’t a substitute either for VENTILATION. Insulating alone won’t get rid of the moisture that humans breath out, the water from drying clothes, the water from baths and showers and the water from some cooking.
All these above can be addressed by tenants but they won’t open windows , the complain about mould and damp
Some don't have enough ventilation, that the landlords problem.And that isn’t a substitute either for VENTILATION
Where are the dogs? Any food with my old dog would be like that film, gone in 60 seconds (probably less). same with most dogs. Don't know much about cats except that they're lazy ****ing things.
Many rental properties have pay as you go meters
In my experience if you treat people reasonably most of the time they respond in the same way...There is a very good reason for that.
Nonsense.Some don't have enough ventilation, that the landlords problem.
Garbage. You clearly don't understand buildings and the idiosyncrasies of occupancy.Homes have windows
Nonsense.
Opening windows just a little is more than enough and costs nothing to implement
"Delivering a narrative conclusion, the Manchester North senior coroner said ventilation in the one-bedroom flat was not effective."Nonsense.
