I'm in the process of laying pipework from a new heating system.....prior to the plumber coming to install the boiler.
I was thinking about capping the ends off once Im finished, and buying a pressure tester. The tester will probably be ebayed after this, as Im only likely to use it once...so I was thinking one of the 0-4bar testers you can buy on the likes of Amazon.
Id guess most plumbers would test with water when comissioning, but Im curious on what the thoughts are of anyone whos used a dry based pressure tester, and if they are a worthwhile bit of kit prior to filling with water?
Cheers
Cheers
