- Joined
- 2 Jul 2024
- Messages
- 48
- Reaction score
- 1
- Country
Hello all
My CU is 18 years old and is doing the job fine. It's the older plastic enclosure box. RCD protects only half the MCB such as ring sockets, shower and kitchen shockets.
Its a fairly small box. 1 of the unmarked is garden brick shed and other I will need to check again. The B6 "Stor" is a single light under the stairs where the CU is installed.
The kitchen is extended building and the cooker is plugged into a kitchen ring socket, not its on MCB. I have seen cooker normally have thier own MCB so not sure what happended here. It was the same sparky that rewired the whole house when I had the house walls gutted.
RCBO were quite expensive intially but has come down in price now so is it possible to fit some RCBO to give a partial upgrade without complications.
1. Is it wise to replace the 3x 32Amp MCB with miniture type A RCBO and rest on RCD??
2. Does it need to be notified to local building regs?
Apreciate any feedback...even if they are harsh truth
