- Joined
- 27 Jan 2008
- Messages
- 28,255
- Reaction score
- 3,432
- Location
- Country
And will that mean just thermostat change, or whole immersion heater change?
Absolutely I noticed that too.The thermostat is set to about 30 degrees in your photo. Why not raise it to 50 degrees. Then you could mix with cold in your shower or bath - it would "go further" that way.
I wonder what your solar system size is ? Your system gives priority to household loads such as freezers etc so potentially on a dull day your immersion is receiving almost nothing anyway ??It is an old photo, I have adjusted the temperature to be as hot as it can without tripping the reset. But the amount of hot water means a couple of dull days, and we run out of DHW.
Ohh so you are charging batteries as well!!Solar is around 5 kW maximum, today 11 am exporting 1.3 kW in summer most days the battery fully charges
the dip in SOC (state of charge of battery) after 5 am until the sun comes out, and DHW is heated with no problems, but a day like this
and the water is simply not heated, the battery was only fully charged with the off peak supply, there was no export on that day, so the DHW was not heated. Had to go back to May for this example when the battery not fully charged by solar, so not too often in Autumn and Spring, Summer rare, and Winter central heating running, so Spring and Autumn is only time.
It's a two minute job, you were close enough to take a photo, no need to empty the cupboard.But all I wanted to know was if looking at picture some one could tell me if I could fit a longer thermostat rather than having to empty the airing cupboard and remove the old one and measure with a bit of wire, it seems the answer is no, so it is empty the airing cupboard to find out.
