We recently moved into a house that has an electric storage heater central heating system (GEC Nightstor). The system is powered from two 63A MCBs in the consumer unit, one a dedicated off-peak circuit (Economy 7) and the other a regular circuit. Upon testing we discovered the heat storage was not charging off the dedicated off-peak circuit. After isolating the system at the consumer unit and removing the cover of the control box I can see one of the cables for the off-peak circuit has completely melted and burnt. The cable that is black and burnt (picture below) was supposedly red originally! It has completely overheated and burnt. Based on the green colour of the oxidation of the copper at the isolator switch screw terminal I am assuming this damage occurred some time ago and the system as been inoperable ever since.
I would like to get the system repaired. However first I would like to understand how this damage could have happened. The cable that is burnt looks to be 10mm2 and is therefore more than capable of carrying the 63A current limited by the MCB. Perhaps the screw terminal became loose, but would that result in overheating of the entire cable length. Help appreciated.
The inside of the control box:
