- Joined
- 17 Aug 2010
- Messages
- 2,888
- Reaction score
- 506
- Country
Well, I can't get very excited by how they are meeting the challenges!was it materially (or at all!) different from the 1995 version
To meet these challenges the BS 1363 series 2023 revision now includes the following
key changes:
• The scope of all five parts now cover operating frequencies from 50 Hz to 60 Hz.
• Modification to requirements for actuating members of switches to include single
push-button switches where the actuating member takes up a single rest position.
• New requirements for switch actuating force test for double-pole switches.
• Insulation and Electric Strength test now includes provision for both indicators and incorporated electronic components to be disconnected.
• Current carrying parts made of brass are required to have a minimum content of 58% Copper.
• Overload test for plugs now requires rewireable plugs to be fitted with 13 A fuse-links
and non-rewireable plugs fitted with highest rated fuse-links specified in Table 2 of
BS 1363-1 for the cable fitted.
• A new requirement forbidding the suspension of a plug or an adaptor in an inverted orientation unless permitted in the manufacturer’s instructions.
• BS 1363-2 now includes tests and requirements for socket-outlets incorporating Circuit Breakers for Equipment (CBE).
• BS 1363-2 now includes a new definition for individually protected socket-outlet (IPS) and includes tests and requirements for IPS.
• Socket-outlet and adaptor switches cannot not be used to switch incorporated electronic
components other than an indicator lamp.
• Modification of mounting box clearance requirements for flush mounted socket-outlets.
• Re-useable fixings of any type, including tamperproof and security screws cannot be used for non-rewireable portable socket- outlets, non-rewireable intermediate adaptors and adaptor plugs.
• Switches conforming to BS EN IEC 61058:2018 or BS EN 60669-1:2018 incorporated in
socket-outlets do not need to be tested for normal operation.
• Modification of Annex requirements for incorporated electronic components. Specifically,
USB circuits intended for charging portable devices with the addition of Abnormal
condition.
• New Annex in BS 1363-2 containing recommendations for products that incorporate
BS 1363-2 socket-outlets.
• Change to the requirements governing voltage and current ratings of adaptors incorporating electronic components.
• New adaptor requirements for the maximum number of socket-outlets on the same plane.
