Good evening
We are currently purchasing a 1960's 3 bed detached bungalow.
At the moment it is heated by a mix of old storage heaters & some much more modern electric style radiators made by Fischer.
The hot water is provided by an old copper emersion tank with a header tank in the loft. Electric Mira shower installed.
We are going to remove the old storage heaters as they are well past the point of no return.
We are going to see how the remaining Fischer heaters perform & cost to run, if acceptable may consider installing through out the property. Installing a solar system is also a possibility.
If we are to install more Fischer units we are looking to replace the existing hot water set up with an unvented cylinder, is this the right move?
If the electric heating does not work out we would look to install a combi boiler, any thoughts on boiler & rad sizes based on the floorplan & insulation in place?
Heating not required in the conservatory.
Located in South Devon so a mild climate, cavity wall insulation in place, 200 mm loft insulation, double glazed through out, solid concrete floors.
Thanks in advance.
Thanks in advance.
