Finding false tripping contacts
9 Jun 2024
I have a wired system and on 2 occasions the alarm has been falsely triggered, during 2 hot weather spells. I am putting it down to a faulty magnetic contact but I have numerous ones on the zone that was triggered, how can I narrow it down as to which one is the iffy one as its an intermittent fault.
And if I make a guess and replace one with a new one then are some contacts better quality than others.
Thank You.
Meter the resistance of the reed switches probably find one that's higher than the others. Are they all on one loop or seperate cables to panel
Thanks they are on 1 loop. 2 zones. I dont know if it was hot weather or that it was left for a couple of days armed - or both, but I have done a couple of tests for a few hours at a time now its a bit cooler and it didn't trigger itself. Can not trust it though.
I dont want to go into too much security details but its not a well known make and was a DIY fit.
I fitted it about 15 years or more and every now and then I do have a contact fail on it but I have been able to find it because it was a complete fail. This one works - until it doesn't and then trips the alarm but I only get an indication of which out of the 2 zones/loopes the trip is on so I do know which zone /loop its on
To see if they are in line ….bad practice to daisy chain contacts as you will never find an intermittent issue with them
On the zone affected I have 5 magnet contacts and 1 PIR. I suppose I could swap them all (faff)
I have tested each contact by opening the window/door and surprised how far the contacts have to be apart before they are tripped so in that respect everything seems fine.
Do the magnets ever wear out / loose their magnitisum
I wonder if I should concentrate on the PIR
The PIR points to a source of sunlight although the sun light is only part of the day and through Venetian blinds.
If the PIR is starting to fail - would strong sunlight cause it to trigger - say coming in and out of clouds. Like I say the two times it has happened it has been a hot day
