- Joined
- 27 Jan 2008
- Messages
- 29,489
- Reaction score
- 3,627
- Location
- Country
I went to get a picture of a loop impedance tester, and found this
in the past cheapest was around the £250 mark, which seemed a bit OTT for DIY use, now retired so even if I have the skills, testers are for DIY use.
The loop test is not the best
it only shows 1 decimal place, most meters I have used show to 2 decimal places, but the plug in testers with loop pass at 1.9Ω so far better than them, and not much more money (£61.72) and also tests RCD's so it does seem to do what I need.
I got a insulation tester a few years ago for £35 which seems to work fine,
a VC60B, the readings match my mega, so seems OK, it does not have a low ohm range, but my old mega does, and I still have that, but wondered if anyone has already bought one and what they think of it.
Link to advert here Comments please.
in the past cheapest was around the £250 mark, which seemed a bit OTT for DIY use, now retired so even if I have the skills, testers are for DIY use.The loop test is not the best
it only shows 1 decimal place, most meters I have used show to 2 decimal places, but the plug in testers with loop pass at 1.9Ω so far better than them, and not much more money (£61.72) and also tests RCD's so it does seem to do what I need.I got a insulation tester a few years ago for £35 which seems to work fine,
a VC60B, the readings match my mega, so seems OK, it does not have a low ohm range, but my old mega does, and I still have that, but wondered if anyone has already bought one and what they think of it.Link to advert here Comments please.
