Hi.
Apologies if this has been asked - can't find if it has though?
I have a Ideal Logic System 24 boiler - giving me the L2 error. One of the reasons i read was it could be low pressure and indeed, my gauge is at 0. If I try to use the boiler it will increase but usually to about 0.8. From what I've read, I should have between 1 and 2 bars.
I think (or hope) what I need to do, is add more pressure into the system. However, I cannot find the filling loop for this boiler. One the underside I have 3 pipes, CH Flow (the gauge is part of this) with a black key, the gas inlet with a yellow key and CH return with a black key. As I understand it - a filling loop connects the mains water to the CH return and you're meant to let water into the system. This is the part where I'm stuck, if the water needs to go into the CH Return - where do I attach the hose (which I also don't have but I assume I can buy one)?
I looked in my airing cupboard and can't find anything obvious.
Any help would be greatly appreciated!
