I have successfully used x800 in both cast iron and low content SE boilersI bet that old cast iron boiler would have tolerated those corrosive chemicals better than this new lightweight one!
be wary on what speed the pump is on, my dad did it on a boiler once and the guy who serviced it noticed and put it back to 3 as thats the boiler requirements (it was a combi boiler, if that makes a difference)Water is still overflowing with the pump on medium speed. I understand that the F&E tank is there to allow for expansion as the water heats up, but have no idea how much expansion is expected in a 150 litre system. I expect there is also an element of restricted pipework contributing to the pumping over. Should this be remedied by adjusting the ball valve to reduce the water tank level by a few inches?
See posts #40/41/42be wary on what speed the pump is on
Agreed, that's why I asked for a sketch of the layout.It needs sorting, which can only be done by investigating why its happening, and either removing any possible blockage in the pipework, or if needs be, reconfiguring the pipework to provide a neutral point between the Vent, Cold Feed and Pump as required.
OK, I got that wrong. Interesting. Can you catch and measure the water which overflows on each start-up? That amount must be getting into the primary circuit. The question is - how and where?By overflowing, I meant water exiting from the F&E tank overflow.
Not really, as long as there is enough water level to allow the system to breather then it should be fine.is there a good reason why I cannot simply lower the water level in the tank?
Does it overflow continuously when heating's on, or rise up and overflow, and then drop back, or what? (apologies if you've already said, it's a long thread!)Sure, I can go back and sit in the loft with a bucket for however long it takes:
If you can't manage a system sketch, it's at least worth checking where the connections are. The modern way is Boiler - Open vent - Cold feed - Pump - Rads, but if it's an old place it might be Cold feed - Boiler - Open vent - Pump - Rads (or possibly pumped return, with a few more options).I haven't actually witnessed it pumping over from the vent pipe, but I guess that's what is happening.
If you can't manage a system sketch, it's at least worth checking where the connections are. The modern way is Boiler - Open vent - Cold feed - Pump - Rads, but if it's an old place it might be Cold feed - Boiler - Open vent...............
It either is or it isn't, it's not hard to check, and if it is, it needs stopping!although I suspect there must still be an element of pumping over.
Can't tell a great deal from the photo. I assume the pump is pumping upwards, and the other white pipe into the suction is the cold feed.I am attaching a photo to show where the new (white) 2 port valve is in the circuit
