Freesat HD box
17 Apr 2007
On my house, which I've lived at for two years, there's a sky dish which presumably was installed at the time of the house build back in 2003/04. All the other houses in the street have a dish too.
I've just tuned my old Grudig Digibox in which I've had since 2005. I can get the likes of Channel 4 and Channel 5 but little else due to HD switch over earlier this year.
Can I simply invest in a Freesat HD box and fit/tune it in to work with the dish?
Do you want to just receive, or to receive and record?
If it's just for watching live, then any Sky HD box being flogged off cheap/given away locally will do. Check Facebook Marketplace. A single cable connection from the dish to the box is all that's needed. Sky's electronic programme guide (EPG) will have a mix of ordinary and subscription channels. The alternative if you just want the straight Freesat HD EPG is a Manhattan SX Freesat HD Box. They're about £70.
For recording, your feed from the dish could do with two cables. This will allow the box to record at least one other channel whilst watching another. You'll also get the 'pause live TV' on Freesat recorder boxes. See here for the Freesat 4K recorders. Freesat 4K recorders range in price from £229 to £299 depending on the capacity of the hard drive.
Freesat (and Freeview) box manufacture is done under licence, and with the Freesat recorders there's only one company with the contract. If it's a recorder box you're after, and you don't want a monthly contract with Sky, then it's going to be one of these Freesat 4K boxes. Satellite doesn't broadcast in 4K. That 4K bit refers to two things.
First, the boxes upscale to 4K output, even with the crappy standard def' channels. Your TV already does this too, but having the box do it does make skipping through the channels a simpler process as it avoids the delay as the TV swaps between resolutions. Second, all these new generation boxes include the ability to access streaming services, and they'll receive and display 4K resolution streams.
There's one other thing with the new 4K boxes. With the right LNB (the lump on the end of the dish arm with the wires connecting to it), then the boxes will record more than one channel whilst you're viewing live. The LNB is the same type that the Sky Q service uses. It's a wideband LNB. These are available to buy and DIY-swap to enable multiple simultaneous channel recording. The 4K boxes will still work with a regular dual cable LNB signal. It's just that you'll be limited to recording one whilst watching another, or recording two channels simultaneously if you're not using the box.
Lucid , have tv (Hisense ) which has Sat connection , tried moving feed from my freesat box to tv but shows no signal? Is there something else required ?
It auto selects Astra 28.2 E Sat , is that correct ?
To add to what @martygturner wrote, is your LNB a Wideband type (Sky Q) or standard Sky HD type?
Alternatively, is your Freesat box one of the 4K models or a Manhatten/Humax etc?
$ky boxes are incredibly energy hungry compared to 'proper' freesat boxes when in standby. Plenty of second-user freesat boxes out there as well as $ky. Only currently made freesat boxes are freesat 4k https://www.freesat.co.uk/get-freesat
Hisense TVs aren't freesat approved afaik... no postcode input so will have a dreadfully random channel numbering and only now/next EPG. A real pain to get into a useful order and then keep up to date as well. (My Panasonic OLED is the same and has twin sat and terrestrial tuners).
Check the LNB settings... LNB power ON, 22kHz tone ON and 9750/10600 MHz as your starters for 10 {the Astra 28.2 degrees East is the correct constellation location, but tuning parameters may not be up to date?}.
My Hisense TV defaults to 9750/10600 under antenna in satellite mode for 28.2 E (a dish/lnb is an antenna as much as a UHF TV aerial is an antenna in techno speak. So ought to work if I connected it to a suitable connection.
Check the F-plug has been inserted correctly... Very easy to fold over the centre 'pin' when inserting into a tight new F-socket (I have the T-shirt) = "No signal".
It’s a standard LNB and works with our Humax 1100.
( cable fitted correctly ).
Model
HISENSE A6N 65 inch LED 4K HDR Smart 65A6NTUK​
Does it offer manual tuning or only auto scan?
Manual scan the 10818 MHz Vertical transponder for the BBC ONE East HD channel (and other BBCs) if you can to start. Other settings you may need to enter / select include DVB-S2, 8PSK, Symbol rate 23000, FEC 3/4.
If no joy call Hisense for advice?
Sometimes a factory reset may be required when devices don't play nicely. But as I said earlier Hisense is almost certainly a FTA satellite receiver so no Logical Channel Numbering or 7-day EPG even if you can tune it in.
I had that, I got it tuned in by a bit of playing around but the channels were all over the place. I changed it for an LG with "proper" Freesat.
On the matter of tuning in a receiver to satellite dish, you can tune the signal using the set up menu on the TV.
I got my signal strength and signal quality to about 70%.
Does using a signal meter provide improved accuracy?
Perhaps not always convenient to see a TV screen when tuning in?
Yes of course it does.
A professional installer uses a meter. Even $ky installers. Proper pro / semi-pro meters tune to one transponder frequency and display info including bit error rates (quality) as well as signal level. Quality (minimum errors) can be more important than absolute signal level.
TV set screen info can be relayed via a speakerphone, or similar to the person at the dish? Not ideal, but has worked for us when caravanning in the past. I also used to know which frequency was one of the weakest to check and optimise, rather than use one of the stronger signals.
